golfbuddah's Avatar
s vs m
Will s calipers bolt on to a stock 73 e car? Thanks
Old 01-06-2010, 02:41 PM
BURN-BROS's Avatar
S have different mount spacing than the M.
PMB sells a S type of caliper that fits the M spacing
PMB Performance: Contact Page (801) 674-3669
Eric is the contact over there.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 01-06-2010, 04:51 PM
The source I checked said the E came standard with the "comfort package" which included aluminum calipers--those would be S calipers. To be certain, measure the mounting holes on your E and see if the spacing is 3.5".
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 01-06-2010, 05:07 PM
djpateman's Avatar
If the E has the correct spacing, it would already have the S calipers in most cases. Only an A caliper would fit otherwise. The M caliper would have a 7mm (1/4") spacer in the center. An S caliper is aluminum with compensating line, and the A caliper would have no spacer between the halves.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 01-06-2010, 05:17 PM
golfbuddah's Avatar
Thanks guys
Old 01-06-2010, 05:26 PM
