Smog air injection pump
Greetings,
I have a question concerning the air injection pump on a 1978 3.0 engine and really respect the knowledge base on this forum. My question is, I lost the belt on the air pump and am wondering if it will harm the engine in any way by running with out it? Or is it actually better, since the car is smog exempt, (1975 911S), or should I replace it immediately? Thanking all of you in advance, Bruce |
Caveman Hammer Mechanic
Mine went missing one day, haven't missed it at all.
eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Mocha BAP
I would replace the belt, or remove the pump altogether and properly store it until need for testing.
They have a tendency to eventually seize if run without the belt. Good working units are getting harder to find these days.
Scott 71 911T Coupe 3.0 Looks stock 79 911SC Coupe 3.2ss Nothing stock 02 996 C2 Cab Mostly stock 06 955 CTTS Super P!G |
You are fine without the belt. I removed my entire air injection setup.
A little less drag on the engine can gain power. Good point, staylo. I have mine tucked away with the other bits I've removed over the years.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne Last edited by Oh Haha; 12-26-2009 at 12:54 PM.. |
It is possible for the exhaust injection tubes to deteriorate over time and heat without the air flowing through them. I removed my pump and the air injection tubes, so they wouldn't brake off in the exhaust. There is a plug that screws into the empty exhaust holes - I think they are from a 914 brake plug:
Porsche 914 Brake Hydraulics - Page 2 Not sure about the part number, but these may be them.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
My 79 sc has a nice condition air pump, but I want to remove it since I don't need it in NY and I like to simplify as much as possible. It looks easy to remove, but what about the hoses, should they be coupled, or plugged? I'm not sure of the consequences of either. it seems many of you have done this, can you enlighten?
Here's a great thread that should give you the info you need.
1977 air (smog) pump removal
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Skisail42 you have a PM!
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
I removed the pump awhile ago, but I couldn't get it's mounting bracket out, there was too much stuff in the way to get it to clear the bolts. Any ideas?
I also left the hard metal air lines in place, because it looked like I would need to remove the driver side heat exchange/header to get to it. The passenger side air lines look easy to get to. I've been thinking of cat bypass anyway. Maybe I should just get under there and take all that stuff off, and get some of those 914 caps. Now the alt fan pulley has an extra groove, too. I will need to find one with only one groove for the one belt.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Since you live in Kalifornia, your 78 is still subject to a smog inspection. The pump, without a belt and hoses connected has a tendency to rust from a small amount of exhaust gas pressure entering back through the injector tube.
Disconnect the hose and cap it then massage the pump periodically before you get the inspection. |
disband
standard proceedure in between cougars in these parts.....
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Targa in serch of worm weather
My '81 Euro doesn't have the airpump system, it was removed and sold by PO. I am moving to Ft Myers, will I need to reinstall the system to clear testing in Florida? Stock 3.0 (930/10) euro engine w/tensioner upgrade, & stock exhaust system. I searched for 2yrs for this car and use it as my every day driver, not because I must but because I want to. It's true, There's No Substitute. Thanks for any help you can give. Will
