How to remove oil filter with upgraded AC compressor
My 911 SC has an upgraded AC compressor. Today I changed the engine oil but could not remove the oil filter. A large AC hose is on the way, just 3 mm from the oil filter. Even if I had space to wrap the oil filter tool around the oil filter (which I didn't), I wouldn't be able to screw it out, because it would be blocked by the AC hose. I have included a picture with an arrow pointing to the problem. Should I loosen the AC hose just a little bit to move it out of the way or do I risk to let the gas out? What other option do I have? Moving the entire compressor, changing the oil filter and then moving the compressor back to its place? Can you imagine having to do that every time I need to change oil and filter? Please help!!
http://forums.pelicanparts.com/uploa...1263074910.jpg |
Undo the bolts holding the A/C bracket to the compressor adapter. If you cannot reach those, undo the 4 bolts on the bottom of the compressor that hold it to the adapter.
Remove the airbox filter cover, set a clean rag across the top of the engine and lay the compressor over the rag. Change your filter, installation is reverse of removal. |
Oil change
That's interesting. I just did an oil change on mine yesterday and didn't have that problem.
http://forums.pelicanparts.com/uploa...1263076312.jpg http://forums.pelicanparts.com/uploa...1263076338.jpg http://forums.pelicanparts.com/uploa...1263076361.jpg I'm not sure what the difference is between our cars. Can you tell from the pictures? |
It appears that the angle of the high pressure line needs to be changed to allow enough clearance for the oil filter's removal. You would do this by loosening the fitting nut after the system had been evacuated.
Regards, mlfox |
Do not loosen the nut with the system pressurized! Besides losing refrigerant (R12 ain't cheap), breathing that stuff isn't so swell either. Hopefully you have enough slack in the hose to just rotate it on your compressor. If you paid someone to install and charge up the system, they should be willing to do the adjustment at no charge since they should have known this would be a problem.
On my SC ( with carbs ) I installed the compressor with the fittings on top. I see you have CIS so you can't do that so " clocking " the existing hoses to gain clearance is your only option.
While your at it get your hoses crimped instead of depending on a hose clamp
This is not a big deal. Loosen the nut 1/4 a turn, rotate the hose up. You are going to lose so little gas you wont even notice. I did this to mine and i dont think I lost any gas. You lose more gas removing the charge hose. Quote:
Handheld A/C Hose Crimping Tool - Tools & More http://forums.pelicanparts.com/uploa...1263137795.jpg |
Why not take the car back to the shoemaker AC guy that installed the new compressor and hose. Was he blind? Make him move the hose and eat the charge or get an estimate, have it done by a better shop and take his dumb behind to small claims court.
| All times are GMT -8. The time now is 02:56 PM. |
