CVJR's Avatar
83 Targa window parts/ window channel
Hello, does anyone know if there is a felt guide piece in the trailing window glass guide in a 83 Targa?
My window is not aglinged properly, it is a bit clockwise when you look at its postion against the top an back rubber.
I dont see a rear felt channel as a replacment part on the Pelican parts site, unless I just don't know what I'm looking at. Wanted to check that before I took the door apart to adjust the glass riser, etc.
Thanks for any help.
Old 01-10-2010, 10:32 AM
steely's Avatar
I'm not 100 percent sure myself.
I was working this project on the windows of my 87, but got delayed.
The PET shows a part for my car, but you're right, Pelican doesn't show it for pre-1987 cars.
Part listing I am talking about is :
911-542-505-40-M Targa, Cabriolet Vertical Window Channel Felt, left or right, Front (1978-89), Rear (1987-89)
I am curious because the felt on the trailing guide was/is completely missing, and there is a white teflon-like part at the bottom of the window that looks like it could ride in the track, but not if there was felt in it.
I have not opened the drivers side door to compare - and I did not find evidence of dried up felt material that would have indicated that it fell out.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-10-2010, 10:49 AM
Here is a picture inside the door of my 85 Targa, with window raised. There is a brass U shaped rail that runs vertically inside the rear of the door, that the white teflon part slides in. The felt is on the front slider only. Hope that helps.
Old 01-11-2010, 05:45 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
I have 2 brand new guides such as those lying around, and they have no felt.
They were bought during the restore of my car, as I thought that the felt would be needing replacement. Turned out there's no felt at all, hence I ended up with a couple more items for the parts bin.
They're for sale if anyone's interested...
Old 01-11-2010, 09:27 AM
steely's Avatar
Thanks TargaDavePerth and prebordao - I hope CVJR sees this.
Dan
Venetian Blue
Old 01-11-2010, 03:50 PM
