Help to Identify which senders these are?
I have 4 senders on my 1983 3.0L motor that has been installed in a 914 and I need help with which ones are for which gauge.
The one looking at the fan on the left with two wires going to the oil tensioner cover, the two on the right going to the block and the feed line for the tensioner with one wire each and the one in the back by the transmission.
I need to identify which one operates which guage!
Here are some photos to work with!
Old 10-13-2011, 10:35 PM
Won Won is offline
Won's Avatar
First one is thermo-time switch, one wire heats up the thermostat inside that breaks the continuity checked by the other wire. Used for cold start circuit as flood prevention function, I believe.
Second pic is the oil pressure sender unit that drives the pressure gauge.
Last one is the "idiot switch" for oil pressure warning light.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 10-13-2011, 10:47 PM
Great, thats what I needed!! Thanks!! What about the one under the oil pressure sender unit? (no photo) It looks similar to the first one but only has one wire connector and comes strate out of the block at the feed line for the pressure sender!
Old 10-13-2011, 10:58 PM
Scott R's Avatar
Screwed into the passenger side chain cover below the sender? That's the 15c switch for the lambda system. Or are you looking at something else?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-14-2011, 06:51 AM
Chief Head Scratcher
kerthunk's Avatar
The one directly under the oil pressure sender is the oil temp sender.
John Morris
'79 911SC
Old 10-14-2011, 07:52 AM
Yes so thanks!!
So the large one is the pressure sender, the one below it is the temp sender, the one in the back is the dummy pressure switch and the one next to the dizy is the thurmo switch for the injection!
Got it!!
Thanks everyone for your quick help. This will help me match the guages in the 914-6 conversion wireing!
Old 10-14-2011, 09:34 AM
