-   -   What's the heirarchy of handling for a 911? (http://forums.pelicanparts.com/porsche-911-technical-forum/520951-whats-heirarchy-handling-911-a.html)
Hotwatermusic 01-11-2010 05:50 PM
Weight distribution<p>Center of gravity<p>Track width<p>Tire grip<p>Weight<p>How would one prioritize these characteristics to make a 911 the best handling car it can be, within its own constaints, of course? For example, is it worth sacrificing overall vehicle weight by having a heavier battery, spare tire, etc. up front giving better downforce and distribution, than not having them there at all (and losing the weight in doing so)? If you had to put these five attributes (and any others I might be missing) in a list, how would it look?
Flieger 01-11-2010 06:06 PM
Tires
weight
weight distribution
suspension tuning
Dantilla 01-11-2010 06:22 PM
I'm no expert, but tire grip is absolutely, without question, number one.
Trog 01-11-2010 06:40 PM
Driver skill.
VFR750 01-11-2010 07:35 PM
Driver skill is #1
Mild Suspension tuning w/corner balance
DOT-R Tires
Brake cooling
More suspension tuning
Aero
weight & distribution
IMHO, a heavy/low powered car teaches you about momentum and smoothness. Once you can hustle a heavy car, weight reduction is icing on the cake.
Hotwatermusic 01-11-2010 08:06 PM
Originally Posted by Trog (Post 5120663)
Driver skill.
Yes, but that's a given. It's read. I am asking if "the Stig" got into a Porsche to drive it, what handling attributes of the car would be most important to him getting around the "Top Gear track" the fastest? And forgive me if these aren't recognized references, as they're only thing I figured most of us might know.
dtw 01-11-2010 08:29 PM
I had been thinking in terms of...
0. Overcommit to corner
1. Don't lift
2. Don't lift
3. Don't lift
4. Don't lift
5. Lift
6. Countersteer
7. Counter-countersteer
8. Depress clutch pedal
9. Depress brake pedal
10. Kill ignition
11. Summon tow truck
12. Engage insurance adjuster
13. Post pics on Pelican
But that's really more of an order of operations than a hierarchy. Carry on.
HarryD 01-11-2010 09:14 PM
Check out Steve Weiner's Web pages on the topic:
Welcome to Rennsport Systems, Porsche Performance Products for the 21st Century
Draw your own conclusions.
Captain Ahab Jr 01-12-2010 02:26 PM
For a classic 911 ie limited to 150mph top speed being used on a road circuit I would go for
Tyres as nothing else comes in contact with the track and this ultimately controls which direction the car travels in.
weight as most lap time will be spent either accelerating or braking. Less is best as it reduces loads on components and your braking efficency improves
weight distribution/C of G as this will improve change of direction during cornering and the a low C of G will reduce lateral tyre deflection improving tyre grip. Sweet spot for front/rear weight distribution is 60-55% rear/40-45%front and as low as you can go on C of G
I would also add chassis torsional/beam stiffness, suspension camber/toe stiffness as being very importantas there is no point trying to make a jello go fast as it will wobble all over the place.
Obviously all this doesn't make up for the spacer betwen the steering wheel and the seat.
Porsche-O-Phile 01-12-2010 02:54 PM
1. Don't lift
2. Don't lift
3. Don't lift
4. Don't lift
5. Lift
6. Countersteer
10. Kill ignition
Touche.
I'd add:
4.5 Panic
9.5 Soil drawers
10.5 Bury head in hands, sobbing
RSTarga 01-12-2010 06:24 PM
slow in, fast out. for the track my priorities would be:
1) tires
2) minimize weight transfer front to rear with stiffer rear torsion bars.
Grady Clay 01-12-2010 06:33 PM
Tires
Tires
Tires
and more.
Yes on all the other but tires, tires, tires.
My racing used a new set of race tires every day.
Sometimes more.
Even then it took very careful tire management.
So long as everything else about a Porsche racer is just OK, tires are the single issue.
Search some of my prior admonitions.
Best,
Grady
Hotwatermusic 01-12-2010 10:13 PM
How "sensative" is center of gravity? Meaning, is it_at_all worth taking out the 1" risers my seats are on, so my 200lbs butt is that much lower in the car? I imagine it wouldn't make a bit of difference, but I would love a reasonable excuse to get rid of them.
Grady Clay 01-13-2010 06:20 AM
In the early ‘70s Porsche built a ‘variable center-of-gravity’ 911. It had a cubic foot of lead on a vertical track through the horizontal plane CG. This ‘lump of lead’ was on a track where it could be just under the roof or through the pan almost touching the ground. I was told it would change the vertical CG by more than 2”.
There is a Christophorus technical article in ’70-’72 about the car and tests. I drove the car on the Weissach skid pad in May ’74.
The conclusions were that a 2” change in vertical CG had about the same effect as the difference between Dunlap 165/78-15 street tires and the period Dunlap race tires. A BIG deal.
So … To answer your question, vertical CG counts a lot.
I understand one of the ‘tricks’ of F1 is to get the car very underweight and add the weight to spec with a tungsten plate under the chassis. This is so effective that F1 regulates the height with wood ‘rub strips’.
Best,
Grady
RWebb 01-13-2010 03:39 PM
Thx Grady - that is another amazing historical tidbit from you.
if pure lead, that would have weighed almost 708 lbs.
I'm surprised that the cubic foot was not some metric unit however.
sig_a 01-13-2010 04:16 PM
1. C/G
2. gross weight
3. tires
4. dynamic load distribution
5. track (baked in by design)
Hotwatermusic 01-13-2010 04:42 PM
Originally Posted by sig_a (Post 5124596)
1. C/G
2. gross weight
3. tires
4. load distribution
Wow, that is a lot different than what others have listed, which is good, I like reading the differing opinions. I knew right off the bat though that I miss-communicated on my original post. By "track width" I meant the side to side distance between the tires--the wheelbase width-wise if you will--I guess I just didn't use the proper term for it. I knew immediately after posting it people would think I meant width of the track the car is driven on. Thanks for the responses everyone, this has been very educational for me.
DanielDudley 01-14-2010 08:01 AM
Best,
Grady
First you make sure your suspension is in good shape, not sloppy or worn. Then you make sure you have good dampers.
Then you get a corner balance, lowering, alignment.
THEN you get tires. BRAKES must work
Fleming 01-14-2010 08:20 AM
Car handling priority
Tires,
but,
Let's not forget unsprung weight.
In talking with the guys at Jongbloed Racing Wheels, lap times (the effect of a good/bad handling car) was a common topic. Heavy to light wheels can be measured in "seconds per lap".
Driving a car with lightweight wheels turns in faster, takes less distance to brake, and had a slightly faster acceleration. The overall distinction is a tighter feeling car - which is much more connected. A by-product is more sensitive tuning of springs and shocks.
Having Fuch's has spoiled us. With 12 lb wheels we gain the handling without ever driving on 20 lb steel wheels to compare against.
Sherwood's wheel weight study is here:
911 Wheel Weights
The down side of very light wheels - they don't like potholes.
sig_a 01-14-2010 09:14 AM
[QUOTE=Fleming;5125569]Tires,
"Driving a car with lightweight wheels turns in faster, takes less distance to brake, and had a slightly faster acceleration. The overall distinction is a tighter feeling car - which is much more connected. A by-product is more sensitive tuning of springs and shocks."
I can agree with that. Moving from 17" Fikse at 25" diameter to 15" Fuchs at 23" diameter improved handling in three distinct areas: lower C/G by 1"; reduced unsprung weight by about 40 pounds total; lowered final drive gear ratio about 8 percent. This is the single most impactive suspension modification so far.
