-   -   How can I tell what profile cams I have got (http://forums.pelicanparts.com/porsche-911-technical-forum/520957-how-can-i-tell-what-profile-cams-i-have-got.html)
matty74 01-11-2010 05:51 PM
I picked up a set of cams for my 993 donk 3.8 re-build, they say 964 super sport but the guy i bought them off said they were GE60 profile.
Is there a method by which i can id the the profile? I have a set of stock cams in my motor, which is/was 993 VRAM, I belive I can use the SS profile with a stock intake where as a GE60 needs itb's or carbs
aigel 01-11-2010 06:04 PM
Most cam shops stamp the profile name on the end faces of the cam. If there isn't anything there, then you need to put them on a cam profiling machine (easiest). You can also profile it yourself in the engine / cam housing with a degree wheel and a dial indicator (best when digital) and plot the cam curve that way.
Hope this helps,
George
matty74 01-11-2010 06:25 PM
yeah it says 964 cup, but the guys said they were a GE60 and the cams have be re-ground so not sure, I was wanting to run ITB's and go GE80 so might send them to camgrinder for a re-grind
aigel 01-11-2010 08:47 PM
Like I said, just get a degree wheel and a dial indicator and you can record the lift per degree, go 360 on both lobes and if you plot the data here, I bet folks can ID the profile.
George
