No Driver's side heat on 83SC...
Hello,
On my way to work this morning I pulled the heater leavers up on my 83SC. It felt that the driver's side lever wasn't as tight as the passenger side. while driving I noticed my side of the windshield was fogged up but not the passenger side. I'll assume that the flapper cable disconnected on the driver's side. I've searched for images on how the cables are hooked up as I will attempt to DIY this issue. If anyone can provide me with images or the schematic would be great and appreciated. thank you in advance for your feedback.
Carl, |
Somatic Negative Optimist
Climb under and you'll see how it connects, PITA.
The small clamping screw to hold the cable-wire is most likely rusted solid. Flapper boxes etc. rust easy because people rarely clean and lube them. Hope you have an easy time to fix it.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
