whats the best wideband 02 sensor
Hi Fellas,
I'm doing a Megasquirt2 efi set up for my 3.8 engine build, what is the best or favored 02 wideband sensor kit out there? Also does any one have map data that will help me get started, I am running RPM of the crank pulley (my canse has had the flywheel sensor mount broken off) from smart racing. Matt |
Matt,
I'm using the TechEdge 2J1 Wideband unit. Wideband WBo2 2J1 Technical Information (Tech Edge) It's worked flawlessly for my and they're in your neck of the woods. T... |
I also have TechEdge and did this full writeup on installing it into the 84-89 911s
http://forums.pelicanparts.com/porsche-911-technical-forum/364450-wide-band-o2-data-logger-84-89-carrera.html |
| All times are GMT -8. The time now is 10:27 PM. |
