khamul02's Avatar
Porsche Crest AC vents .. fyi
I'm thinking of trying the 2" where my bow tie went. I think it will be a bit less visible, and more useful (more directional) than the square models that are being sold for bow tie replacement.
http://www.mtgparts.com
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 01-10-2010, 10:25 PM
Uno Dei Molti Porschisti
BarryJB's Avatar
I built my own trapezoidal vent-under-the-ashtray & added similar vents at the underside of the ends dash, replumbed with heater hose from the wrecking yard, by using inexpensive standard vent & parts from a local RV shop... but based on my experiences this would work well and is less obtrusive. The pipe stub from the plenum sticks out through a slightly larger hole in the vertical surface so you can push whatever you get onto it enough to allow for narrow hose clamp so just make sure it is the right size to fit over that stub & inside the hole.
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024
Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon".
Old 01-16-2010, 01:33 PM
