-   -   CV Hardware substitute (http://forums.pelicanparts.com/porsche-911-technical-forum/521677-cv-hardware-substitute.html)
OldTee 01-16-2010 08:03 AM
78-9 SC CV hardware calls for pan head M8 X 50 1.25 screws.
Why can't you use standard M8 X 50 1.25 bolts (hex head)?
Sacrilegious?
NineOhOne 01-16-2010 08:32 AM
As long as the hardness is correct for the application, I don't see why not. My '79 has allen-head cap bolts.
Gunter 01-16-2010 08:50 AM
Pan head? Where do you see that pan-heads are required? Pan-heads are mostly used to fasten sheetmetal. Porsche calls for M8 x 1.25 x 50 Socket-head (6mm Allen key) machine bolts
As long as they're 12.9 quality, you could. You also need good lock washers like Schnorr-type and the half-moon plates.
Sacrilegious?
Apply the correct torque. CV's coming loose are no fun. :(
