my car has 15x6 & 7s would like to put 16x6 & 7 or should I go with 16x7 all around tires 205x55x16 or 215x55x16 no flares as of yet. I saw a clean wht early car in foutain valley with 16x6 & 7 on wednesday tried to catch guy but he was gone. I have chrome with blk between spoke 16x7 fuchs.I want to put on, car is red tan int, 2.7 euro piston w solex cams mfi...Any info would be great.....Thanks Matt
Senior Registered User
IMHO- 7"x15" or 16" Look really great on an early car, on all four corners.
Back when the early cars were much newer, if your car didn't have 7x15'sx4 corners it was not kewl. You needed a pair of H-1's as well. Randy Jones 1971 911 Randy Jones 1971 911 |
Re: 16 fuchs on a 72t
Matt, On my '69 I have 16x6........205x55x16 on all four. Looks great and no rubbing. The 215's in the rear will rub. Don't flare your car. |
Monkey with a mouse
Re: Re: 16 fuchs on a 72t
I have 16x6 Fuchs at all corners w/ 205/55 SO2s.
(edited 11/16/01) Rears are fine w/ 1.5 degrees negative camber - fronts rub at front fender w/ 1.1 degrees negative camber and postive caster set at 5.2 degrees! I think Anderson recommends 15x7 at all corners w/ 205/55 tires (tyres!). My goal is to have 4 15x7 911R wheels w/ an R compound 205/55 tire. Donations can be sent to . . . Best, Kurt Last edited by kstar; 11-16-2001 at 08:35 PM.. |
I have 2 mint 6 x 16 with full polished rims to sell. I recently picked up 7" for the front to go with my rear 8".
