Batt. in Smugglers box question
Hi,
I'm going to install a battery relocation kit from Rennline. Question is: Has anyone relocated the grounding post to this area? If so, where did you put it? I don't have the kit yet but I'm doing a lot of cutting and welding. Also, if you do have the kit but didn't move/install a new ground post, where could you put one? Thanks much |
I used a welded stud that protrudes from the passenger side of the rear of the smugglers box for the ground. I DID relocate the positive post to the area which used to be occupied by the battery. In this manner, I only had to run a thick cable from the battery to the post and all of the original fuse connections did not have to be extended. I did shorten the starter cable and relocate to the battery within the smugglers box. Pretty simple - just fish back under the drivers floorboard and up through a vent hole...
If you look closely you can see in the picture below:http://forums.pelicanparts.com/uploa...1264115126.jpg |
I used one of the bolts that secure the clamp for the steering shaft assembly that resides within the smugglers box. Follow the white battery leads in this picture:
<img src="http://img251.imageshack.us/img251/6843/pict0002lb.jpg" alt="Image Hosted by ImageShack.us"/><br/> |
Just what I was looking for... thanks.
The only other question I have is: Did you cut off the three bolts protruding from the pass. footwell and the other two protruding from the wheel house? (presumably for A/C) Also there are some vents that could be welded shut and a cable tidy (metal strap near the three bolts) Did you do anything with them? On aside note: NICE trunk! Very tidy. |
I see... you got the cut switch. I wasn't going to get it but I bet it makes repairs much easier.
Thanks again. |
Kinda off topic but for early cars where Porsche saw fit to purposely put TWO batteries in the front wings is there a degradation in handling when moving to a single batt. in the smuggler box?
You may or may not be able to feel it. But maybe it's not enough to worry about. In my own car I can tell if the spare tyre is in place or not. It's not a stark difference.... but it is noticeable to me. It's hard to explain but the front end feels a bit lighter when pushing hard through the corners. Also If I'm accelerating out of a corner it can feel just that little bit more wayward... Loose almost but not dangerous. Don't get me wrong. It's not a bad feeling but it is noticeable. |
Here's a shot of my smuggler's box battery installation. I used a Rennline cradle and welded a stud outside of the box and secure the ground cable with a wingnut - just like Porsche used to. The cutoff switch is mounted on the stock box cover.
http://forums.pelicanparts.com/uploa...1264121446.jpg |
Why do you put the battery in the smugglers box? Weight distribution?
yes - it affects the polar moment of inertia
I thought that by taking the weight from in front of the front wheels and moving it further back would have a negative effect on our Weight heavy rear end cars?
You're undoubtedly more or less correct, but I think mass centralization is the key. As well, switching out the 50 pound battery for one that weight a quarter of that and moving it closer to the center of the car is good for overall weight distribution.
Here is another install.
http://forums.pelicanparts.com/uploa...1264173625.jpg The master kill is under the lid. In this case intended more for security than safety. |
Where did you get the bracket for your battery disconnect switch?
Lengthening the wheelbase in '69 helped greatly; effectively decreasing the polar moment in the rear. |
Smuggler's box was originally designed to hold the webasto gasoline powered heater on the early cars but that was a rarely spec'd option.
| All times are GMT -8. The time now is 10:48 AM. |
