Gilles, if you want the one I have that is slightly damaged on the end of it, I can send it to you to use until you can find one. I just looked at it again and a resourceful guy could repair it with a little bit of FG cloth.
cab owners...http://forums.pelicanparts.com/suppo...leys/shake.gifhttp://forums.pelicanparts.com/suppo...leys/shake.gif
must stem from our ties to C.R.A.P. |
When I purchased my '88 Cabby, those hand pulls were attached with sheet metal screws. You can order those from our host....if you can't find the part number, talk to one of PP's Service Reps.
http://forums.pelicanparts.com/uploa...1295299987.jpg http://forums.pelicanparts.com/uploa...1295300041.jpg http://forums.pelicanparts.com/uploa...1295300093.jpg http://forums.pelicanparts.com/uploa...1295300144.jpg What is the consensus on replacing that rear insulation piece with something made of a modern material? |
| All times are GMT -8. The time now is 11:32 PM. |
