Mitch Leland's Avatar
Upholstery Finish Washers...
I'm missing some of the 3.5 washers w/ the serrated backs for the oval head philips sheet metal screws, I'm told the factory washers are NLS.
Does anyone have a source for these washers or a good substitute? I have the standard sheet metal ones that will cut into the upholstery material, I want a solid back like the factory finish washers.
Thanks,
Mitch Leland
"84" 911 Turbo Look
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 01-23-2010, 07:43 AM
Keepin' it Simple...
R_Builder's Avatar
I have some I won't be using. How many do you need? Are they black or chrome?
-Doug
1968 911R Clone; 11/07-?? (forever the project car )
1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers)
1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home)
1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany)
Old 01-23-2010, 07:55 AM
Upholstery Washers...
Doug,
Aren't you nice... I'm looking for 6-12 of the smaller 3.5 washers. See pix. Pelican carries "protection washers" for attaching the door pockets. Those washers are for the 4.2 sheet metal screws and I'm assuming those washers are the same as the 3.5 washers (however Pelican says that the 3.5 are NLS), except with a larger diameter hole.
I've attached pixs of both sizes, showing the top and bottom of the washer. I hope yours are the same. You can PM with your e-mail address if you like.
Many thanks,
Mitch Leland
Old 01-23-2010, 05:36 PM
