Upper strut mount nut removal
Does anyone have any good tips on how to remove the front upper strut mount nut?
Any tips on how to keep the mount with rubber underneath from turning along? + Is it normal that the lockplate is "bended" upwards to the nut? I already bended it down, sprayed WD40 multiple times but the nut still won't budge ... ![]() Thanks! Last edited by Url; 02-01-2010 at 10:34 AM.. |
i use an air impact.
poof! gone |
sorry for my feeble memory. but doesnt that large washer have a pin that slips into the slot on the shock's threaded shaft? can you grab it with large channel locks? and counter turn it?
poof! gone |
+1. There is a thread with picture on this. I used this method, works.
Fat butt 911, 1987 |
AutoBahned
try a cheapo manual impact device
WD40 is NOT a penetrating oil BTW - buy loctite freezeoff, kroil or pb blaster etc. - time and tapping are needed (hundreds of taps over several days) never seen a lock pin but you can use big pliers on these things |
Zuffi-Freund
I ended up with my Dremel - second best if you have no air impact at your hands. Anyway you can not re-use the nut.
******************** best regards Heiko Porsche 911, 74 Lachs-Diamant Metallic |
I fought this thing for two days about a month ago, many four-letter words were involved.
In the end it was a pipe wrench on the washer that did it, but even that took a while because it kept slipping off the washer.
Aaron '81 911SC RoW Targa |
An impact solves all of your troubles-no worry about twist, breaks the nut loose, etc.. Buy a heavy electric version if you don't have a compressor. Every tool box should have an impact, especially working on older cars.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Weekend Mechanic
+1 for penetrating oil (kroil or PB Blaster) and an impact gun. Air or heavy duty electric. If you're going to do work on a Porsche it is a massive time saver. What will take you hours with hand tools will take minutes with a gun.
J
86 911 Carrera Targa
Use a decent pentrating oil.
Grab the big dished washer which a pair of channel locks or pipe wrench, the washer has a key that fits in the slot of the spindle nut. Hold channel locks tight (a helper is not a bad idea) and use a box end wrench to turn the nut. Won't budge? No impact wrench? Make your own! Wack the box end wrench with a hammer while assistant holds washer with channnel locks. Lather, rinse, repeat.
Why not?
It is the third item from the left on the lower row of this picture: ![]() Thanks Fleming
I'm sure an impact gun is the "best" answer, and hopefully I'll have one someday. But in the meantime, the pipe wrench I used was $14.
Zuffi-Freund
Hello Harry,
get a new one! They are self securing, if you take a close look you will see, that they are not perfect round shape. It is more "oval" so the nut fixes better when put back. You will have the same trouble fixing it again without impact wrench.
porsher
I cut two flats on the washer so I can hold it with a wrench, instead of fighting with channel locks and such.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Model Citizen
The pipe wrench did the trick for me, and IIRC, the new shocks came with new hardware, but I like the idea of two flats on the washer...
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
I second the use of a pipe wrench. I just did this job this past weekend. An 18 inch (made in USA) pipewrench to hold the round disc and a breaker bar on the nut did the trick easy-peezy. I replaced my Boge inserts with Bilsteins.
1987 911 Carerra Coupe 2006 VW Jetta TDI two german black beauties
