964 decklid install on 82SC trouble
I'm trying to install a 964 decklid with spoiler on my 82 SC and it appears the spoiler tray rubs on the heater hose/pipe, there's not enough clearance. What have others done? Is there a need to relocate the heater hose that goes over the fan, do you need to trim the underside of the spoiler tray to get this to work? I thought other than the hinges it was pretty much a direct fit.
I did a quick search and it seems that most have gone to a backdate style heater setup that eliminates the "over the fan housing" hose as well as relocated the coil to get the needed clearance.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
exactly what I did + remove a trim piece that extends full left and right so it doesn't hit the PMO air box's
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
What trim piece are you referring to? The piece on the decklid?
Where can I purchase the heater backdate ducts? Does anyone have the part numbers for what I need?
911-106-322-01-PH and 930-106-321-01-PH from the Pelican catalog.
Just as an alternative I saw someone that routed that over the fan heater hose around the back of the engine. But you cam get the backdate pieces at Partsheaven.
91110632700
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
El Duderino
Got pics of your 964 decklid on the 82?
like this?
87 944S (gone) 18 4Runner 08 Honda Ruckus 81 Targa SC |
#4 is called "rear wall" this is w/a carb install so no comment on CIS I also have parts diagram, part #'s, electric diagram, and other operation/install stuff
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 Last edited by RoninLB; 06-20-2012 at 07:21 AM.. |
El Duderino
Nice!!! I am liking this idea. Following this with interest.
