Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
DJB DJB is offline
DJB's Avatar
Brake wear indicator light
I checked my brake pads three weeks ago, when I replaced the brake lights switches and bled the brakes.
The pads seemed fine with enough meat. The brake light indicator light is now on. Indicating either wear or a fault.
If it is wear - how long have I got?
If its faulty any ideas where to start looking?
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 11-17-2001, 10:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Your question poses a few more questions: I assume that this light was not on prior to the pad changes and the sensors were not worn breaking the connection. After changing the pads, the sensors were replaced properly? Generally, new sensors should be replaced with the pads. They deteriorate/crack from heat often. I actually made a set of sensor adapters from an old pair that are just a looped connector that plugs in. No more annoying light. I remove/replace my pads from track to street 1/2 dozen times a year and the track pads don't have sensor slots. Being that your rotors cost over $200 a pop, I can see why you would want to be aware of your brake thickness. After checking all the connections, try replacing the sensors to start if you can't find the one that is at fault.
Old 11-18-2001, 06:35 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
