Is this an aftermarket AC cut-out?
Hi,
I have this hole into the smugglers box on my car:
It looks uneven and home made, maybe with a dull knife. But, can anyone tell me what it is for? I'm guessing it's for an aftermarket AC unit, but I'm not sure.
Can I just weld it shut or do I need to take any other things into consideration?
Thanks,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 01-26-2010, 02:11 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Looks like a hack an aftermarket idiot would do... Here is some geniuses solution for rear hoses on mine.. and the "after" I patched it.
Gary R.
Old 01-26-2010, 02:17 PM
khamul02's Avatar
yep
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 01-26-2010, 02:19 PM
NineOhOne's Avatar
I have the same, except mine is much more jagged. Looks like it was done with a can opener. I can see the condensor(?...evaporator?) through it.
Originally Posted by jsoderbe View Post
Hi,
Thanks,
Johan
Old 01-26-2010, 08:33 PM
Ok, thanks. Just to weld it together then. I have a dondor body that has the vent and all in it, so that should be an easy fix. So there are actually worse cutouts around?
Johan
Old 01-27-2010, 07:10 AM
Mine looked almost exactly the same. The AC was supposedly put in at the dealer (it was the VPC AC unit which has the large smugglers box cover.) You're fine to cover it up.
1973 911T | Four owner car | My stewardship (2008-Present)
1972 VW Super Beetle | Two owner car always in the family | Gone, but not forgotten
Old 01-27-2010, 08:44 AM
