Stripping gas tank found a screw in top?
I purchased a used gas tank for my 911SC and noticed some rust on the underside flange of the edge and so proceeded to strip off the rubber undercoating on the tank. The only thing I found that worked well was a 4 inch wire brush on the end of my drill.
On the top of the tank, on the side opposite the filler neck, I found a small hump that was covered with the same grey undercoating as the rest of the tank, when I took off the undercoating I found a small philips head screw in the tank. There is absolutely no rust around the screw and when I removed it there was a small round clear plastic piece in the tank that the screw went into?
Is this something Porsche did or was it a prior owner?
Should I braze the hole shut or leave it as is?
Thanks for you advice you have.
dog
Old 07-27-2010, 04:52 AM
Senior Member
A picture would help.
Old 07-27-2010, 05:03 AM
Fleabit peanut monkey
Bob Kontak's Avatar
The clear plastic piece tells me it ain't Porsche. Someone may have mounted a CD changer or other something-or-other
Since it is out I would have it brazed then re-coat the textured stuff. There will be a cost to prep it (tank boil?) for brazing but it would be worth it to me. I suspect you could use a petroleum proof epoxy but I would always be leery if it is holding.
Old 07-27-2010, 04:54 PM
Zeke's Avatar
Why not just put the screw back? Run a ground wire so it looks official.
Old 07-27-2010, 05:00 PM
Took pictures last night, they are still in the camera sitting in the garage.
I took a better look at it and it isn't a plastic piece, it is a metal piece that the screw goes into and looks like it belongs there, could it be for a ground?
Old 07-28-2010, 04:15 AM
Bob Kontak's Avatar
I like Milt's idea best.
Old 07-28-2010, 05:21 AM
vash's Avatar
i had my gas tank cleaned. they had to drill a hole for some reason..i asked. cant for the life of me remember why..i think it was to pour the sealant? or to blow vent air? he showed it to me, when i picked it up.
it was as you described..plastic plug with a screw in it.
EDIT!! i remember! it was to drain the excess sealant..the plug was in a low spot..a corner so that they could lean it up and drain all the excess!!
poof! gone
Old 07-28-2010, 08:00 AM
I took Milt's advice and put the screw back in.
Old 07-29-2010, 09:13 AM
dshepp806's Avatar
Good info.
Thanks,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-29-2010, 12:32 PM
I didn't use it as a ground, just put the screw back in and started re-coating the tank, using Eastwood products.
Here is a picture of the screw, as I said it is on the top on the left side and should not be a problem.
Old 07-30-2010, 05:09 AM
1969 912 (2.4l 1973.5)
ppanagis@gmail.'s Avatar
Send a message via Skype™ to ppanagis@gmail.
I had my gas tank redone 2 years ago. They did not need to drill a hole in it. If the tank is out and clean can't you just have it welded?
http://img.photobucket.com/albums/v468/patpan/DSC01142.jpg
Old 07-30-2010, 05:39 AM
brd brd is offline
brd's Avatar
Oooohhh... Be careful with the idea of welding. It's very difficult to get ALL fuel vapour from the tank and I've heard a few stories of tanks going boom. Brazing could be an option.
Old 07-31-2010, 02:42 PM
