fxeditor's Avatar
Who needs a Crankcase Breather Gasket anyway!
So I am moving on to my next fix, the replacement of the crankcase breather cover gasket. It wasn't leaking (I don't think) but I thought "while I'm in there. . ." So I open up the cover to find this:
That's right, Nothing! good thing I'm doing these now!
Quick Question, Do I use a little gasket sealer on the mating surface of the case to the gasket? I think I remember saying to do it somewhere but I can't remember now.
Thanks,
Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 01-28-2010, 05:16 PM
sudo apt-get purge 930
equality72521's Avatar
That looks like gasket sealed to the crankcase to me.
--clutch-monkey
Old 01-28-2010, 05:27 PM
DUK DUK is offline
DUK's Avatar
Uh yea.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 01-28-2010, 05:31 PM
plymouthcolt's Avatar
The surface is silver. Yours is black. You think that is caked on oil-it's not. It's your rock hard gasket. You need to put a clean rag in there to prevent bits from falling into your engine as you scrap off the rock hard gasket material.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 01-28-2010, 05:33 PM
fxeditor's Avatar
It's not. there is just metal of the crankcase. I triple checked. Sorry the pic is so lousy, my point & shoot isn't good for macro shots.
-- '92 Miata
Originally Posted by DUK View Post
Uh yea.
ok
--clutch-monkey
Old 01-28-2010, 05:53 PM
DUK DUK is offline
DUK's Avatar
ok
Sorry didn't mean it to come out as negative. But I still think there is a gasket there. Look at the left side of the surface in the picture it has a step like a gasket not lining up with the edge of the surface of the block.
2000 & 2007 Dobies
Old 01-28-2010, 06:00 PM
Sorry, I took that the wrong way. I agree there is a gasket there.
--clutch-monkey
Old 01-28-2010, 06:06 PM
fxeditor's Avatar
OK, I started scraping and you guys are right, there is a gasket there. Sorry. What's the best way to get rid of this baked-on mess?
Michael
-- '92 Miata
Old 01-28-2010, 06:40 PM
Stuff a clean rag in the hole to prevent particles from falling into the crankcase and then use a scraper to remove the gasket. Any minor remains can be removed with scotchbrite or mild sandpaper.
--clutch-monkey
Old 01-28-2010, 06:44 PM
80-911SC's Avatar
scraper ........ but put something in the hole before you drop a load of stuff in there....
scraper , you can use a razor blade , they have spray on removers and solvents but a razor (not bic) will work fine.........
Old 01-28-2010, 07:24 PM
The old adage applies. If it doesn't leak, don't fix it - or something like that.
I'd leave the gasket intact, then reinstall the cover with Loctite 574 case sealer or equivalent. This is a low pressure joint. Not worth the time and effort to remove a gasket that will eventually fragment into a hundred pieces.
Instead, spend that saved time by detailing your engine compartment.
Sherwood
Old 01-29-2010, 12:20 AM
dshepp806's Avatar
Vacuum as you go,..don't wany ANYTHING to get in that engine
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-29-2010, 01:18 AM
