'89 930
73.5 simple wiring question
Hi All,
Getting close to finishing the 73.5T conversion to a 3.0L and have a question in the rear engine compartment wiring. What is the 2 plug wire connector shown here. It has a red/blk wire and a brown wire with a white parallel stripe. The plug has a plastic pin in the middle. I am trying to pick up a wire in the rear that would provide a 10 amp supply to the XDi twin plug coils. I suspect this plug went to the rear defog via the 3 fuse panel on the CDI console or something, all of which I no longer have.
'89 930 3.4, twin plug, crank fire, K27, cams, B&B I/C, coil overs, EVO '73 911 'ol Yeller - 3.0 ST Clone '74 911 green with NV - 3.6 RSR to be '87 951 Red Vitesse Stage 3r, AOR, Ruf, Motion Control '01 996 ECU flash, 911Tuning exhaust, DV, Techart |
That would be for the rear window defroster heating grid.
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) |
'89 930
Thanks Jim
