GVW GVW is offline
Question 5th gear problem?
I have a 1983 911SC and I'm having a problem when I am in 5th gear and want to shift back to 4th. It has a tight feel to it. I have to put a little elbow grease into it. It goes into 5th no problem, but has a tight feel coming out. I have not adjusted the clutch recently or had any other tranny work. I installed the factory short shift kit a while back and had no problems since then, until now. I drive the car very little and have had no trouble after installing the kit. I have close to 1000 miles on the car since I put the kit in. Any suggestions?
Thanks in advance, Glen.
Old 11-19-2001, 07:31 PM
Hmm, adjust the shifter, change the tranny fluid, and check the adjustment of the clutch. Just the first things that came to mind.
Old 11-19-2001, 08:19 PM
