Rookie Tranny Install
I am getting ready to mate my 3.0 to a 915 and reinstall. I want to make sure I grease the right locations. I have attached some pictures and would greatly appreciate someone identifying where to grease. To the extent you can also describe what I am seeing in the picture, that would be great so that I make sure I have the correct terms.
1976 911s Targa
1976 911s Coupe
Old 02-20-2010, 08:17 AM
grateful user
don gilbert's Avatar
i would replace all your seals and the plastic bushing that your throw out arm pivots on. also the pilot bearing to. cheap and good insurance.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 02-20-2010, 08:40 AM
How do you remove/install pilot bearing? What about the grease?
1976 911s Targa
1976 911s Coupe
Old 02-20-2010, 04:02 PM
<insert witty title here>
Christien's Avatar
Basically, you want to grease any moving part, aside from the flywheel itself. The pilot bearing is a damn good idea to replace - a failed one caused my rebuild, and it's pretty cheap. It just pops in and out. It's what the splined shaft in your 3rd pic will slide into when you mate them.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 02-20-2010, 07:12 PM
Somatic Negative Optimist
Gunter's Avatar
I hope you have the Bentley SC Repair Manual. If not, get it.
The pilot bearing sits in the center of the flywheel; remove, clean, inspect, replace if necessary and lube with EP2 grease or Moly.
Remove the guide tube (Picture #3) and replace the O-ring inside. Lube the outside of the guide tube and the inside of the release bearing and the splines on the input shaft.
Dismantle the cross-shaft (Picture #4), inspect the bearings and seals, replace if necessary. Clean and inspect the fork for wear and cracks.
The Bentley explains terminology of the parts with pictures and what to lube.
Judging by the grime and dirt, the disc and release bearing may need replacing?
Does the disc still have enough life left on the lining?
Release bearing still smooth?
How many miles on the clutch?
Make sure to engage the fork into the release bearing when assembling.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 02-21-2010, 11:16 AM
