911t Fanatic's Avatar
tranny seperation
Trying to seperate the tranny from the engine but i seem to need 3 spacers and allen head screws to release the clutch spring. Is their any other way? If not where can i get the parts i need to do this? Need help fast.
Old 01-30-2010, 09:14 AM
Please help!
Old 01-30-2010, 09:51 AM
Oh Haha's Avatar
The year and model of car would help. Also, what transmission?
Do you have it out of the car?
Pacific Blue
Wayne
Old 01-30-2010, 09:53 AM
1970 911t engine is out ( 2.2 liter) sorry
Old 01-30-2010, 09:56 AM
sounds like a 70/71 issue. you do not need spacers etc. you pull the release fork back away from the throwout bearing and turn the bearing 90° with a screwdriver. keep the trans bolted to the engine when you do this. engine and trans out of the car as a unit of course.
if it's a later car, the release arm is removed under the bellhousing before sliding the trans off the engine.
206 637 4071
Old 01-30-2010, 09:57 AM
Great.. i do have the mounting bolts loose. Ill tighten them up and give it a shot Thanks a million. Be right back to see if it works!
Old 01-30-2010, 10:00 AM
one more thing how do you pull the release fork back? do you mean on the clutch lever?
Old 01-30-2010, 10:01 AM
tranny seperation
Success Thanks John!
Old 01-30-2010, 10:45 AM
