donyount's Avatar
wood facia
I have done a few searches and looked at a lot of 71 interiors. I only have seen basketweave. Is this a stock option on my car? Is this wood "real" if it is. I hate it but might like it if i sand and re stain to make lighter. Otherwise going with brushed aluminum or similar.
I have seen wood on early 911s then the fake stuff later ect...
thanks for comments.
Don Yount (Texas)
1968 911s/r rally car
1971 911e
1971 Norton Cafe Racer
2007 Elan DP02 American Lemans Lites
Old 02-01-2010, 11:59 AM
Classic's Avatar
Don,
Your 71 should have basket weave in place of the wood in the bright dipped aluminum trim
Our host has it for sale.
The Aluminum trim should be held on with double sided tape, be careful not to bend it when you remove it.
The vinyl is just glued into the grove of the trim, and raps around each pieces end by about 5mm.
Hope that helps
Classic 1969 911T
Old 02-01-2010, 01:28 PM
donyount's Avatar
wood
Thanks for info. Someone must have added this later in its life.
Don Yount (Texas)
1971 911e
Old 02-01-2010, 04:32 PM
I think 66 was the last year with mahogany dash
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-01-2010, 05:05 PM
AutoBahned
RWebb's Avatar
as stock or as an available option?
my '73.5 has the wood - may be an aftermarket thing
I keep seeing them on mid-70's cars...
Old 02-01-2010, 05:16 PM
1965 and 1966 911's had wood dash trim as standard. After 1966, wood wasn't available.
JR
Old 02-01-2010, 08:13 PM
