zugelassener benutzer
teamfee3's Avatar
No brake lights which switch - PICS
OK, stupid question #86, brake lights functioned periodically and then stopped., I am assuming it's the brake light switch. I have an '86 so it's one of two options - 2 pole or 3 pole. Here are some photos can anyone tell - 2?. Also, this seems really hard to get to, can anyone offer some help with the process. No garage and it's winter in MD with a 10 day repair order from a dilligent cop.
Thanks.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 02-01-2010, 11:52 AM
Diss Member
Quicksilver's Avatar
First thing to make it more complicated there are 2 switches back there. You need to pull some of the hoses so you can see back there.
It should be a 2 pole switch. There is a cheap VW switch that works and is usually locally available.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-01-2010, 12:10 PM
MBruns for President
JeremyD's Avatar
Most likely a two pole - but just pull off that nylon connector and you can tell for sure - Mostly the turbos had a three pole connector.
You can remove with the brake booster still in the car - I'd recommend prefilling the switches - there's a few threads that cover it -
JeremyD's Avatar
Here you go bubba. Find a friend with a garage -
No brake lights
Old 02-01-2010, 12:13 PM
teamfee3's Avatar
I can't get my sausage fingers in there. Not sure if it's relevant but the 2 pole switch has an "H" suffix and the 3 pole a "G" and my VIN ends Z"G"S122605.
I am interested in the division with '86 cars - what was it all about?
32C #7
Old 02-01-2010, 12:15 PM
Happiest when Tinkering
gsmith660's Avatar
Replace those prone to fail pressure switches with a mechanical switch I did it 25 years ago after my third switch replacement in 2 years. just pull 1 switch plug and rig up a wire harness to go down to the pedal assembly plug one wire into each harness plug wire (plastic socket)and let the switch do the rest.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 02-01-2010, 02:37 PM
