Url Url is offline
Url's Avatar
Upper strut mount nut removal
Does anyone have any good tips on how to remove the front upper strut mount nut?
Any tips on how to keep the mount with rubber underneath from turning along? + Is it normal that the lockplate is "bended" upwards to the nut? I already bended it down, sprayed WD40 multiple times but the nut still won't budge ...
Thanks!
Old 02-01-2010, 10:30 AM
vash's Avatar
i use an air impact.
poof! gone
Old 02-01-2010, 10:36 AM
Url Url is offline
Url's Avatar
I don't have one (yet) Any other suggestions?
Other question: can you "break" something if you twist the strunt mount too much? (rubber etc.)
Old 02-01-2010, 10:41 AM
vash's Avatar
sorry for my feeble memory. but doesnt that large washer have a pin that slips into the slot on the shock's threaded shaft? can you grab it with large channel locks? and counter turn it?
poof! gone
Old 02-01-2010, 10:49 AM
rnln's Avatar
+1. There is a thread with picture on this. I used this method, works.
Fat butt 911, 1987
Old 02-01-2010, 11:58 AM
AutoBahned
RWebb's Avatar
try a cheapo manual impact device
WD40 is NOT a penetrating oil BTW - buy loctite freezeoff, kroil or pb blaster etc. - time and tapping are needed (hundreds of taps over several days)
never seen a lock pin but you can use big pliers on these things
Old 02-01-2010, 12:01 PM
Zuffi-Freund
Hesse James's Avatar
Send a message via Skype™ to Hesse James
I ended up with my Dremel - second best if you have no air impact at your hands. Anyway you can not re-use the nut.
best regards
Heiko
Porsche 911, 74 Lachs-Diamant Metallic
Old 02-01-2010, 02:01 PM
Head416's Avatar
I fought this thing for two days about a month ago, many four-letter words were involved.
In the end it was a pipe wrench on the washer that did it, but even that took a while because it kept slipping off the washer.
Aaron
'81 911SC RoW Targa
Old 02-01-2010, 02:19 PM
efhughes3's Avatar
An impact solves all of your troubles-no worry about twist, breaks the nut loose, etc.. Buy a heavy electric version if you don't have a compressor. Every tool box should have an impact, especially working on older cars.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-01-2010, 06:44 PM
Weekend Mechanic
vulcan300's Avatar
+1 for penetrating oil (kroil or PB Blaster) and an impact gun. Air or heavy duty electric. If you're going to do work on a Porsche it is a massive time saver. What will take you hours with hand tools will take minutes with a gun.
J
86 911 Carrera Targa
Old 02-01-2010, 07:02 PM
HarryD's Avatar
Use a decent pentrating oil.
Grab the big dished washer which a pair of channel locks or pipe wrench, the washer has a key that fits in the slot of the spindle nut.
Hold channel locks tight (a helper is not a bad idea) and use a box end wrench to turn the nut.
Won't budge? No impact wrench? Make your own! Wack the box end wrench with a hammer while assistant holds washer with channnel locks.
Lather, rinse, repeat.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-01-2010, 07:16 PM
HarryD's Avatar
Why not?
Harry
2020 MB E350 4Matic
Old 02-01-2010, 07:17 PM
HarryD's Avatar
Yep,
It is the third item from the left on the lower row of this picture:
Thanks Fleming
Harry
2020 MB E350 4Matic
Old 02-01-2010, 07:38 PM
Head416's Avatar
I'm sure an impact gun is the "best" answer, and hopefully I'll have one someday. But in the meantime, the pipe wrench I used was $14.
Aaron
'81 911SC RoW Targa
Old 02-01-2010, 07:49 PM
Zuffi-Freund
Originally Posted by HarryD View Post
Why not?
Hello Harry,
get a new one! They are self securing, if you take a close look you will see, that they are not perfect round shape. It is more "oval" so the nut fixes better when put back. You will have the same trouble fixing it again without impact wrench.
best regards
Heiko
Old 02-01-2010, 09:56 PM
porsher
aston@ultrasw.c's Avatar
I cut two flats on the washer so I can hold it with a wrench, instead of fighting with channel locks and such.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 02-02-2010, 06:23 AM
Model Citizen
herr_oberst's Avatar
The pipe wrench did the trick for me, and IIRC, the new shocks came with new hardware, but I like the idea of two flats on the washer...
Old 02-02-2010, 06:33 AM
derandjer's Avatar
I second the use of a pipe wrench. I just did this job this past weekend. An 18 inch (made in USA) pipewrench to hold the round disc and a breaker bar on the nut did the trick easy-peezy. I replaced my Boge inserts with Bilsteins.
1987 911 Carerra Coupe
2006 VW Jetta TDI
two german black beauties
Old 02-02-2010, 07:51 AM
