Send a message via AIM to tmblackflag Send a message via Yahoo to tmblackflag
overflow hose on brake master cylinder
has anyone had issues with pressure leaking out of the overflow hose? I have a c-clamp on the hose, but it is leaking where the fitting meets the master cylinder. Im Iosing about 1 psi per minute
1986 3.2 Meteor Metallic Grey
Old 04-27-2013, 01:18 PM
to add a little more color, I can spin the hose freely on the plastic piece that leaves the master cylinder, and moving in different directions makes it leak more or less
Old 04-27-2013, 01:20 PM
I've got it clamped off at the red arrow, but it is losing pressure from the yellow arrow area. I would like to try removing this fitting but not sure how that metal brace comes loose without ruining it. I pulled on the hose from the MC pretty firmly and feel like i'll break the plastic nipple.
I've got some vinyl hose i'd like to toss on there and c-clamp. It should be a snugger fit.
Or should i just c-clamp as I described and keep adding pressure to the system as I bleed with the Motive?
Old 04-27-2013, 01:55 PM
Northern Motorhead
wildcat077's Avatar
I removed the original clamp at the resewrvoir nipple as it was too loose anyways,just cut it off and use a normal hose clamp.
When i bleed with the motive i remove the drain line and use a small section of hose with a bolt pressed in at the end to keep the pressure.
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-27-2013, 02:16 PM
Cheers !
Phil
thank you sir!!
Old 04-27-2013, 02:18 PM
