Part number of the filter for a 72 is 901 201 023 05.
Grady, to clarify, you plugged the original return / bajonet opening and use the gas heater opening right? Only worry is water build up at the bottom of the tank. Did you experience any problems? Ed |
I'm a bit confused. Left is my fuel filter, middle my return line and the right is redundant. So to Grady's solution, the return should go into the right port using an old filter? What to use to plug the old return line?
Thanks for helping. Ed http://forums.pelicanparts.com/uploa...1273695922.jpg |
| All times are GMT -8. The time now is 07:02 AM. |
