cheap brake bleeder
here's a custom bleeder, made from a 914 or bug windshield squirter hose, and a 911 fluid reservoir cap. drill a hole in the cap and attach the threaded end to it with a nut, or a metal valve stem cap with a hole drilled thru. attach the hose to your spare tire or the left front tire, adjust pressure to 25#, and bleed. don't forget to clamp the overflow hose from the reservoir.
206 637 4071
Old 11-21-2001, 01:40 PM
Bill Douglas's Avatar
Very smart idea.
I was going to crack an irratating joke about a brake bleeder that's even cheaper, plus does the dishess and vacumes the house - but I won't.
Bill '79SC.
Old 11-21-2001, 02:10 PM
tbitz's Avatar
Here is my cheap bleeder in action. I pump my bottle up with a compressor, but a bicycle pump would work too. A hole was made on the pop bottle cap and a silicon hose was glued in place with some PL premium construction glue. After the bottle is compressed the hose is connected to the overflow nipple on the master cylinder resevoir.
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 11-21-2001, 06:07 PM
is there no end to the ingenuity?
206 637 4071
Old 11-21-2001, 06:17 PM
