| Bill Verburg |
02-08-2010 04:12 PM |
Originally Posted by Superman
(Post 5174045)
...... Anyway, I suspect this sort of complete sidewall failure can only happen if the tire is WAY low on air, the sidewall heats up over time and BOOM. Am I correct?
I suspect that is correct
(Post 5174045)
Second: I have been led to understand that the weight of your car divided by your tire pressure(s) equals the number of square inches of tire contact patch you have. If so, then what good does are wider wheels and tires? If they don't increase the size of your contact patch.
Not quite, the tire carcass also contributes.
It's the combination of lower stiffer sidewall and the shape of the contact patch that is important. The sidewall stiffness is fairly obvious and intuitive, the shape not so much. The shape is important because of the way grip is developed by the contact patch. Grip is developed by the contribution on each little piece of tire compound along and just behind the leading edge of the contact patch and the twist it develops, The sum of all the little twists is called the slip angle, the more little pieces lined up the more lateral grip is added. The greater the slip angle to a point the greater the lateral grip. The down side of the twist is heat in the tire, you want to twist enough to generate grip within the tires design range but limit the heat generated as a by product.
In general the wider the tire the lower the slip angle needed for a given level of grip and the cooler the tire will run. wider shorter side walls run at lower slip angles than taller narrower tires. Contributing factors are wider wheel widths, within design parameters, which support the tire better and suspensions which reduce unwanted extraneous wheel and tire excursions.
(Post 5174045)
And besides, why would size matter anyway? In my hometown, a logging town, it is widely known that wide tires perform poorly in the woods.Tall, narrow tires are what they use. They grip better.
different design goals, they are not generating lateral grip, they are generating longitudinal grip, the narrower tires tends to cut down through the softer surface layers and grip the more solid under layers, this is particularly true for snow where there is usually nice hard pavement underneath, offroading in soft bottomless sand requires a wider lower pressure flotation type tire, probably w/ traction devices well up the side walls.
