I haven't done much to my car, I have only tracked it a few times.
Shifter Bushings, BIG help SW Chip, well worth it. |
drilling holes in keys, door handles... = pointless
for a newb the most important things to do are in the long term + commonly neglected maintenance thread |
Light flywheel = 5 for auto cross, 2 for daily driving
WEVO Shift kit = 5 no miss shifting from 5th to 2nd |
I'll throw in my $0.02, although I'm far from an expert.
1. A very extensive cleaning of the interior. Not an upgrade so much, but like seats and wheel, when you are inside the car it makes a big difference. But maybe I'm just saying this because when I bought my '75 it took me three days to clean the interior and exterior, the car was so incredibly dirty. It looked completely different when I was done. Replacing seats will be my next interior upgrade. 2. Shifter bushings. The first project I ever attempted. Easy to do, inexpensive and gives gratifying results. 3. Front oil cooler. This is my next big project, to get the turbotrol mounted and working correctly. Performance? Won't make the car faster, but will make the engine last longer. For pure performance, you probably can get pretty good bang for the buck with exhaust upgrades, particularly if you can source a higher performance one from the used parts classifieds here. Good thread! I'll be following the suggestions here. ---- Tom '75 targa |
Street car basics for a '74 w/SC motor (personal ratings):
1) Carrera chain tensioners (5) 2) Air box pop off valve (5) 3) Lower to Euro spec (4) 4) Bilstein shocks (4) 5) Modern sticky tires (4) 6) Remove A/C (3) 7) Light weight, cloth sport seats (3) 8) Bosch H4 headlights (2) 9) Strut brace (2) 10) Turbo tie rods (2) Markus '80 SC Targa |
DE car / weekend driver basics for a '83 w/carrera motor (personal ratings):
1) Turbo tie rods +5 2) Bilstein Sport shocks +4 3) Better Tires +5 4) Remove A/C +2 (I miss the comfort) 5) Light weight sport seats +3 (again I miss the comfort) 6) Strut brace +2 7) Spoilers +4 8) Back-date heater +2 9) Brake upgrade (MC + calipers) +3 10) 993 Brake cooling fins ++5 - best 40 bucks I spent |
Thinking back to all the mods I've made over the years, the most dramatic improvement resulted from replacing my shift-coupler.
I picked my car with most of the upgrades already installed. 1st group were at the top of my list.
- premuffler, sport exhaust - mild chip (but turns out this was false) - k&n intake & filter - 17 inch & tires - lowered to euro specs - H4 headlights - Nardi wood wheel - Momo anatomic shift knob - stainless door thresholds - racing pedals - fog delete front valance w/ chin spoiler |
Great thread! Thanks Hotwatermusic! I totally get what you're asking for and agree that it's useful in making a strategy.
Here's where I'm at: Picked up a 1978 911 SC that already had; Carrera cam chain tensioners, Carrera fender well oil cooler, bump steer spacers, turbo tie rods, turbo valve covers and 97k miles with "fair" paint (chips/scratches but totally rust free and straight). What I've done: Momo steering wheel - 4 - much better feel (the original wheel's leather was coming apart, otherwise I would have waited) ER quick release front strut brace - 3 - I can feel a big difference in downhill tight mountain switchbacks but you have to be "on it" to feel the dif New oil/filter, Swepco tranny fluid, valve adjust, plugs dist cap/rotor and tune up - 5 - peace of mind :) Polk Audio 6 3/4" component door, 4" separate tweeter rear - 4 - PO's speakers were blown Radiantz LED rear tail/brake lights - 5 - they are bright, instant and last a long time! New front bonnet shocks - 4 (got to throw away the PO's wooden dowel 'system' ;) Aimed lights, set tire pressure, lubed hinges, adjusted cables, got familiar with systems Current "problems": Brakes pulse - pads and rotors are near their end Synchros are rubbish 1st, 2nd, 3rd (I'm actually enjoying the 'game' with heal toe, double declutching all over the place making my commute feel like the opening to "Le Mans" :) Slop in the suspension...I can feel the worn bushings Heater box in dash is "sticking" or at least protesting, but that's fine I don't know what it does anyway ;) Shifter is sloppy So here's my list of To Do: Brakes - I'm currently looking at a set of Carrera calipers and rotors and ordered stainless DOT lines WEVO shifter - the vintage look and possibly the Precision Shift Joints (anyone try these?) Tranny - having a complete tranny rebuild and adding the WEVO 915 Gateshift (anyone try this?) Suspension this is the big one... ER raised spindles, Bilstein HD, Poly Bronse (or their rubber bushings), new strut and shock tower rubber bushings, Engine mounts, stiffer sway bars, and SLIGHTLY stiffer torsion bars that match the shocks (I go with the custom valved VONS) I want the ride quality of my previous 99 Boxster, but with stiffer sway adjustable bars so I can set corner attitude. Engine SSI Headers, with M&K two in, one out exhaust (oil lines as well) Lightness/rightness backdate heater w/floor fans, remove A/C, remove rear bumperettes, remove(d) passenger flag mirror (PO previous problem), replace driver flag mirror (HEAVY!) with Talbot aluminum Lighting Relay (on order), higher wattage bulbs for Hella H4, and Hella driving lights Stereo replace crappy install of AWAI CD-skipmaster with Alpine and amp Paint the stock paint is a little rough, and since I'm keeping it black, I'm hoping it wont cost an arm and a leg, or need to be stripped down to get a fresh coat of goodness Wheels ...eventually...after all of this, 17 inch Fuchs style either Alton or Zuff.. I'm sure that I will add to/change this list (...hmm backdated wide body hotrod with Big Reds...hmmmm) but I thought I'd chime in with my thoughts. I'm an ex race/champion winning motorcycle roadracer, previous DE junkie and have autocrossed for years in CRX, Integra, Boxster, WRX, and I currently race Supermoto and flattrack motorcycles so I'm pretty good in a whip. I do, however need to learn Blackjack so there will be DE and auto-X in my future...but I don't want to turn her into a track rat machine. Oh and by the way. I LOVE MY 911 !!! Even as is, it's so engaging and has such character under the blemishes that I enjoy my commute every day! haha I just also love to improve upon a good thing with balance and without removing the character or soul of the machine. I also want to keep her very streetable, that retains the touring ability and the soul of an epic sports car. Thanks for the great forum community! I'm enjoying this part very much as well! Cheers, - CraigD |
I think I slipped off the edge a long time ago....but elephant spring plates are looking way good !!
To me the best upgrades were in descending order from most value to least:
Turbo tie rods(gives steering a very direct feel)5 Steve Wong chip + Fabspeed pre muffler4 Bilstein shocks3 Swepco in transmission3 Boxster brakes over Carrera rotors(this is controversial, but I like it)3 Strut brace2 RennAire pro cooler0(save your money) |
sometimes the upgrade depends on what is wrong with the car or what you are going to do, IE, de's, autocross, daily driver.
sloppy shifting? short shift kit vs just replacing all the bushings. ride height too high- rear? suspension bushings, torsion bars in my case, torn, dryrotted seats- upgraded to sport seats. and the big one, engine needs rebuilding = bigger and better. for me, my 2.7 is tired so i bought a 3.0 to rebuild |
I couldn't agree more with the comment to fit new shift bushes and coupling. I had a really notchy box that was sloppy in 1st/2nd and too tight in 5th. After 3 hours at my local mechanic's the car came back feeling completely different. if shifting is an issue then definitely do this.
I used to quote the speed of my car as 0-60mph in 6 seconds PLUS GEAR CHANGES but now the sarcasm doesn't seem justified. Another improvement I had done was to replace the pre-muffler on passenger side (my car is RHD) with tuned headers. This keeps the exhaust length the same on both sides which dramatically improved drivability sub 3500rpm. Doesn't do much for horsepower but torque is improved lower in the gear. I was really surprised at the difference. SSI's would have been another option for me but the cost difference in parts and labour is about 5 times as much. More $$$ for other tweaks. |
Upgrades
Change : [rating] : ~$$ from what I can remember.
Comment Seine Shifter "gate spring" for 915 transmission: [9] ~$150 Great difference on street but incredible secure feeling on track. Bilstein Sports (rear): [5] ~$260 pr Only tried on street, not track testing yet. Strut Brace: [3] ~$250 Got it early in my P-car ownership, so it's hard to compare. Race seats: [7] ~$300 (cheap pair) Upgrading to OMP TRS's Really does hold you in at autocross and DE. 4 or 5 point belts: [5] $? MOMO Prototipo: [7] $190 Great feel. Smaller diameter of original. Headers/2 in 2 out muffler: [8] $1400 ~14hp increase EFI: [8] $2300 ~14hp increase Fuchs, 7 and 9: [9] $1500 Front/rear FG bumpers and FG duck tail: [8] $1400 Really helped get my car down to around 2260# Rebuild foot pedal/bearings (gas/brake/clutch): [8] $20 Big difference. Rebuild shifter bushings and linkages: [8] $30 Big difference |
I did some things for my eyes, some for comfort and others for faster responsive driving.
Love the look ! - 7” & 8” Fuch replicas - Kumho ASX 225x50x16” and 245x50x16” - Also put on a Carrera tail and a front valence/lip from 84 up with recessed fog lamps - 5mm rear wheel spacers - New axles and CV joints - Adj. rear drop links - Rear sway bar - Bump steer kit - Strut brace - New ball joints - New ARM bushings - Elephant racing poly bronze front bushings - Bilstein shocks- front/rear - front skid plate - Sway bar bushings - Turbo tie rods - Alignment + Corner weighted - Cross drilled rotors - New brake pads front/back - Stainless brake lines - 380 mm steering wheel - Short Shift kit - Shift coupler - shifter bushings |
As my 86 cab was neglected when I bought it the following were necessities rather than upgrades:
If you have an SC then make sure you have a pop off valve, Carrera chain tensioners and upgaded steel head studs.
| All times are GMT -8. The time now is 02:47 PM. |
