1988 911 Brake Rebuild Question
Hi All,
I am hoping to start and finish the brake calipers as soon as the snow lightens up in the NY area. I want to know if it is easier to jack up one wheel at a time, or just put the car up on jack stands and redo the wheel cylinders, then change the rubber lines one at a time, then bleed the system?
Jack
Old 02-10-2010, 04:09 PM
I did this very task in september. Jack the entire car up and put in on supports. DO NOT forget to partially depress the brake pedal and keep it there with a stick or something while taking the lines apart. Otherwise the fluid will drip out and air will get in there. Ask me how I know. Might as well get caliper rebuild kits too if your dust shields are shot. Rebuilding the calipers is super easy and they will likely work better once all the gunk is removed and new seals put in place. Get a pressure bleeder too. Makes the task even easier. Get teh right wrenches too, forget what they are called, but they are more than combination wrenches.
good luck
Carl F
2000 Ruby Red Dodge Stratus with high performance racing stripe SE edition WTF? (sadly gone, but not forgotten)
1997 HOnda Accord "Shaggin Wagon"
1987 All black Targa
1998 Lemond Zurich/Dura Ace
2005 Jamis Dakar Sport
2006 Lemond Reno
2 DOgs , 2 Cats, Shi@ton of fleas
1 Cool as Hell Wife that tolerates my stupidity
Old 02-10-2010, 04:23 PM
winter
Winter's Avatar
Jack - you may find some of the replies to my post about my brake issue in this thread helpful, I know I was stoked to learn about the homemade pressure bleeder.
Gimme a BRAKE!
Regards.
Tom '75 targa
Old 02-10-2010, 05:45 PM
There is an article in the recent Porsche Excellence, on caliper rebuilding.
Old 02-10-2010, 09:03 PM
I would recommend pressure or vacuum bleeding. Excessive travel of the brake pedal can ruin your master cylinder seals.
Old 02-11-2010, 09:51 AM
winter
Winter's Avatar
I suppose you could go try to find a copy of Excellence but maybe easier to just click on this link:
Pelican Technical Article: 911 Caliper Rebuild
Good luck.
Tom '75 targa
Old 02-11-2010, 12:42 PM
PMB Performance
Eric_Shea's Avatar
Jack... yank them all at once.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 02-11-2010, 01:44 PM
Just bought the issue on your tip. Thanks very much.
Looks like a perfect article on a 911 brake caliper rebuild.
Jack
Old 02-12-2010, 12:38 PM
