-   -   Problems with pressure bleeder (http://forums.pelicanparts.com/porsche-911-technical-forum/52615-problems-pressure-bleeder.html)
john70t 11-21-2001 12:25 PM
Well, I finally finished my front wheel bearings and it feels great, a corner balancing and alignment and we'll be all set.
[Some tricks that worked: I put saran wrap under the resevoir cap and tightened it back down and used hose-crimp pliers-hardly lost a drop of brake fluid, Also freezing the races and heating the hub to 350 deg made removal/install quick. The hub was put on 2x12 boards with a junk rotor bolted on.
I also put a griding wheel on the old races to take of a few thousanths, flipped them upside down and used them to 3# hammer in the new ones- work fast, hit hard and evenly.]
When I put the pressure bleeder on about 5 pounds, fluid started pouring out the front end around the winshield washer resevoir area- my guess is that the hose pressure-fitting from the resevoir to the Master cylinder lost just enough seal to piss all the fluid into the frame that flowed forward onto the floorevenly and sealed itself up again (I didn't lose any more fluid from the resevoir after that).
What technique seems to work best on old 911s (1 person). Mity Vac? Gravity bleed?
makaio 11-21-2001 12:29 PM
The Motive pressure bleeder kicks butt!
Doug Zielke 11-21-2001 04:01 PM
Re: Problems with pressure bleeder
Originally posted by john70t
When I put the pressure bleeder on about 5 pounds, fluid started pouring out the front end around the winshield washer resevoir area........
If you're using the Motive Products pressure bleeder, you need to:
1) Make sure the m/cyl pressure cap is on very tight.
2) You must remember to pinch off the m/cyl vent line.
(But you knew all this...didn't you?)
john70t 11-21-2001 05:13 PM
Never heard of a MC vent line, thanks for the info.
VenezianBlau 87 11-23-2001 04:04 AM
Yeah, I agree with Matt. The Motive power bleeder I ordered from PP is great. I haven't used it on my '87 911 yet but used it for the first time yesterday on my '00 Jetta. Worked like a charm.
Bob Sauerteig
