christojen's Avatar
Does this look normal? - clutch / omega
Hi Guys,
My symptoms are a heavy clutch in 77 911. I jacked up the car to look at the helper spring and levers - i would love to hear if things look normal in these pictures.
Thanks Chris
Old 02-12-2010, 08:20 PM
sudo apt-get purge 930
equality72521's Avatar
Looks pretty normal to me. Check the spring on the clutch pedal itself.
--clutch-monkey
Old 02-13-2010, 04:19 AM
Oh Haha's Avatar
It looks to me like the omega spring is not "over the hump", so too speak.
At rest, it should almost touch the heat exchanger. You may not be getting any of the spring action which would cause a heavy pedal.
Also, that clutch cable looks in need of replacing. The rubber boot is torn which will let dirt in and corrosion will start. The cable itself could be causing some problems as well.
Check this out for what it should look like.Clutch Auxiliary Return Spring aka Horseshoe Spring or Omega Spring
Pacific Blue
Wayne
Old 02-13-2010, 05:56 AM
E Sully's Avatar
You should make sure the arm is greased and moves on the shaft. It looks like it is hanging up.
Old 02-13-2010, 06:51 AM
