Part # needed to finish clutch rebuilt
I need a part # for that little bushing that goes on top of the release fork of a 915 Tranny "1986"
see pic: ![]() mine, after cleaning, fell apart ,..poof gone,.. By the way the aluminum pressure plate from the Sachs power clutch kit is only 4 lbs lighter than the steel OEM, does this really makes a difference?? I though the Alu. plate was much lighter than that,.... Thanks for any help Stephan
1992, 964 Carrera 2, Midnight Blue 1998 BMW 318ti 2004 BMW R1100S BCR 2017 BMW R1200RS 2017 BMW 435i Mpower Pkg |
915-301-139-00-M30
Porsche 911 & Carrera Clutch & Flywheel - Page 7 The 915 uses three of these. I just finished a clutch myself..Engine drop pics comming soon
Do a search in PP for P/N "915-301-139-00-M30". Pelican has them for $2.50 each with 3 required for your 1986 year.
When I did my 84; I had a gap with only 3 so I ended up putting in a 4th to keep the dirt out. I also put in the Al pressure plate. I don't know if it goes any faster, but it sounds faster when you blip the throttle.
Doug ![]() 84 Carrera Coupe - Black (the Goth look) ![]() The more I learn, the more I realize I don't know
3,.... I only saw one on the tech article for clutch rebuilt,...!
Where do they all go ,...one on top of each other or on each end of the fork,... help please see mine as it is now. ![]() By the way anyone knows why those little things do not show on the parts diagram,...?
1992, 964 Carrera 2, Midnight Blue 1998 BMW 318ti 2004 BMW R1100S BCR 2017 BMW R1200RS 2017 BMW 435i Mpower Pkg Last edited by YZR500; 02-14-2010 at 06:22 PM.. Reason: adding |
I hope I said that right...LOL
As for the other two; The factory manual shows one above and one below the "clutch release lever" (the big arm). Hope this helps,
Thanks a lot, I've just placed the order with PP.
