-   -   Color of wires to micro switch (http://forums.pelicanparts.com/porsche-911-technical-forum/526575-color-wires-micro-switch.html)
tobluforu 02-15-2010 09:36 AM
In an attempt to get the fuel shutoff to work on my 72 mfi, I need to know what the colors of the wires are that connect to the micro switch. The wiring harness that goes to the fuse/relay block located on the drivers side, engine compartment has been taped with three different colors of tape. Black, red and blue and in the process of removing the tape I found two wires taped together which look to be white or maybe gray with a red strip. These two wires are cut and have no connections, but it sure looks like the wires I’m looking for, anyone know if these are the right colors?
Eddyvdw 02-15-2010 10:00 AM
Mine are grey/red, both wires.
Here you find the diagram:
Electric Wiring Diagram 911 (1972) - Elektrische installatie - Techniek 911 en 912 - Klassieke Porsche 911 en 912 Club Nederland
Good luck,
Ed
911E 1972
tobluforu 02-15-2010 10:42 AM
Those are them,
Thanks much!
