R22tech's Avatar
Unhappy Fuel leak is back...so is cold weather.
I posted several months ago about a slight leak on the fuel line at the point where the rubber hose meets the metal flared fitting, specifically at the crimps. I temp. fixed it by installing an alligator clamp around the metal fitting and just tightening the $hit out of it. It has worked for probably 7 months, but now it is getting colder and I suspect the metal is contracting causing the problem to resurface. Yeah, I know, just replace the line...try $500.00 plus without labor! My tech looked at it awhile ago and said, off the record, my repair was fine unless the leak showed up again. So my question is, can I just refit and tighten the clamp again or is there another way of remedying this problem without having to replace the line. The leak is very, very small.
85 Carrera Targa (sold!)
03 Dodge Ram 1500 HEMI
Old 11-21-2001, 01:51 PM
Senior Member
Hello
I would renew the rubber hose as it maybe have slight cracks inside and will bulb up or leak. This normaly happens when you absolute are not needing it. ( murphys law )
You need a little saw and then you slice the pressed steel end down until you hit the tube. Then use a vice grip and remove the rest by rolling off.
Cut the rubber hose away and replace it with new stuff and very solid and wide crimps.
Grüsse
Old 11-22-2001, 06:03 PM
Bill Douglas's Avatar
An idea. Can you snip a bit off the end of the rubber so a new fresh part is slipped over the metal (so you are loosing the bit that may be perished or cracked) and maybe tighten it with a couple of alligator clamps.
Old 11-22-2001, 06:37 PM
APKhaos's Avatar
Hey R22... best shot is to locate a local operation that fabricates aircraft fuel lines. One that does military stuff is even better. They can build a stainless braided line assembly for around $100.
There was a post on this subject recently - the owner found a fabricator over near Andrews AFB near DC which did a great job. Beats the daylights out of $500 to replace with the same failure-prone OEM line!
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 11-25-2001, 04:38 PM
