-   -   Need '88 3.2 DME Schematic (http://forums.pelicanparts.com/porsche-911-technical-forum/527050-need-88-3-2-dme-schematic.html)
der Mond 02-17-2010 06:58 PM
I have a buddy on another forum that needs a wiring diagram/schematic for the '88normally aspirated 3.2 DME unit. Can help?
steely 02-17-2010 08:16 PM
Not to bait you, but this site/link used to be working :
http://www.the944.com/ml31dwg.htm
...hopefully it's a temporary issue with them.
Also, I don't know how close/different the 944 is to the 911 DME, but try googling for the following 2 files:
ML31TAU.pdf and ML31TDU.pdf
maybe someone else can provide a better response.
on edit: sorry you asked specifically for 3.2, the 3.1 references were all I had
Geronimo '74 02-18-2010 01:13 AM
He asked for the schematics for a 3.2 litre Carrera 1988 (that is what I understand)
http://www.cannell.co.uk/Technical%20Articles/ML31TAU.pdf
http://www.cannell.co.uk/Technical%20Articles/ML31TDU.pdf
How about these? (Dunno if they're identical to the ones of the prvious poster)
der Mond 02-18-2010 06:46 PM
Hey thanks, guys - the site from Steely had the 1987 911 schematics, presumed to be correct for '88 - '89 also. Geronimo, the ones you attached are for the 951, which are also on the site. THANKS GUYS, YOU ROCK!
