vinny c's Avatar
trim screw
Replacing upper door felt and quarter window trim on my '80 SC and can't find the screws that I carefully labeled and stashed. Found one and it's 3mm x 10mm flathead black oxide.
I need at least 34.
Any ideas where to get these?
Vince
Old 02-17-2010, 06:03 PM
Eagleday has them.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 02-17-2010, 06:39 PM
steely's Avatar
You may have already Done this, but can you get the part number off of the PET catalog?
Will send you a PM too.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-17-2010, 07:18 PM
Mitch Leland's Avatar
I just went through this with some interior upholstery oval head screws. Glenn from Pelican warned me that Porsche gets an arm and 2 legs for their screws. A sheet metal screw, albeit with black oxide plating can be $1.00 per screw from Porsche. There is very little difference between an SAE and Metric diameters in sheet metal screws. The SAE will work fine. However for the few missing screws I used S.S. screws and painted the heads with a black satin finish.
If these screws were going to be exposed to weather then I would want the oxide finish.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 02-17-2010, 10:08 PM
vinny c's Avatar
Thanks for all the responses.
Vince
Old 02-18-2010, 09:54 AM
