rstoll's Avatar
Clock Repair 83 SC
Does anyone know the value of the two electrolytics on the PC board in 83 Clock. VDO doesn't put values on any of their components. (wonder why) I put two 220uf at 16 V in mine and it is running. Will take 24 hrs or so to check for accuracy. I have checked it to 15 minute accuracy, it's ok so far.
Robert Stoll
83 911 SC
83 944
Old 11-22-2001, 09:42 AM
Senior Member
Doug Zielke's Avatar
Robert,
We all know you're a smart guy, but just how did you know the clock needed new caps?
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 11-22-2001, 05:19 PM
rstoll's Avatar
Ha, Well Doug, one cap would sweep...the other wouldn't. But when I heated the defective one up to remove it the clock started running. I had an old Volvo Speedo with a couple of 220s in it. Changed both of the caps in the clock. It has been 9 hrs since the repair and it's good to the minute! Whatasave!!!!
Robert Stoll
83 911 SC
83 944
Old 11-22-2001, 05:47 PM
81Targa's Avatar
Are you sure that clock isn't a Timex?
Roger
Old 11-22-2001, 08:13 PM
Robert,
How do you take the clock apart? Looks to me like the front facia needs to be removed. I can't see how to remove it w/o boogering it all up.
Any secrets?
Thanks in advance,
Doug '84 911 ROW.
Doug Christensen, 1984 911 ROW (Lauren)
Old 11-23-2001, 04:16 AM
rstoll's Avatar
Carefully pry around the band with a small flat screwdriver.
Robert Stoll
83 911 SC
83 944
Old 11-23-2001, 04:20 AM
Senior Member
Hello
you can set the clockspeed on the little screw on the back. As far i remeber each mark is a minute in 24 hours. VDO tried to achive swiss precison. Even a change in voltage will not affect the time.
Grüsse
Old 11-23-2001, 03:51 PM
