1997 993 Stalling Issue
Recently, after driving long enough to warm the car up, it will start stalling when I come to a stop. There are no problems when cold and I recently cleaned the ISV - which needed it badly. Other than the stalling the car runs strong and as you would expect.
Any ideas? |
Hi,
How old are the oxysensors? With a clean and functioning ISV, these do not stall unless there are some vacuum leaks, old primary oxysensors, etc. |
Have you disconnected the battery recently?
If so, it will take a while for your car to 'reset' itself. If that's the case, the only fix is driving it. |
Thanks for the ideas. I have not disconnected the battery. I will look for vacuum leaks and check out the O2 sensors.
| All times are GMT -8. The time now is 03:10 AM. |
