Blockchain Tech Inventor
I got in the 911 to go to work this morning, it was a little chilly, windows all fogged up. Put the defrost on, one notch short of the high setting. After about two or three minutes, the window was getting defogged and as I was ready to pull out, I started to get smoke? steam? streaming out the vents - mostly from the passenger side area including under the glove box and out the A/C vent (A/C not on). What a nasty smell! Although, I can't say it really smelled like smoke or not, more like some really nasty stale cigarette/cigar smoke. I think it was more like steam since it dissapated right away and stopped when I turned the heater off. I rolled the windows down and drove to work without any more problems - no heater.
I am assuming/hoping this is not a huge problem. Normally I park my car in the garage, however, for the last few days it has been outside as I am storing a friend's 914 race car in my garage while their house is getting remodeled. I drove the 911 on Thursday, about 70 - 80 miles round trip - no problems. It was parked since Thursday night - also, Thursday night we had some torrential downpours and more rain on and off over the weekend. I am assuming water got through the grill and into places it shouldn't be. If that is the case, is this something that will dry on its own, or do I need to do something? Of course, when I tried to pop the engine lid this morning, I couldn't get it to release and everyone else had left already so I didn't have anyone to push down on the lid to see if I could get it open that way. What do you guys think? Thanks, JrDavid68 1986 911 Carrera |
Maybe you got some water inside the heat exchangers. They aren't sealed, and can get water (and oil) inside them.
Bill Krause We don't wonder where we're going or remember where we've been. |
Thanks Bill. So, should I do anything? Or when I get off work today should I roll the windows down, crank the heater on high, turn up the tunes and hit the freeway for awhile to dry it out? Good excuse for some spirited driving!
I also had a friend suggest that my windshield could be leaking a bit and some water got down in the fresh air vents - any thoughts? Thanks again! JrDavid68 |
If you drive with your heat off, air still gets forced through the heat exchangers but then exits at the flapper boxes rather than entering the cabin. If my heat smells a little, I just turn the heat off for awhile and that usually clears it out.
I don't think a leaking windshield will get water into the ventallation system. Water (and snow) can get into the fresh air plenum, but there is a drain hole that allows water to drain under the car (or into the trunk if it's not connected right).
