-   -   Installing sound pad, will this stuff work? (http://forums.pelicanparts.com/porsche-911-technical-forum/52773-installing-sound-pad-will-stuff-work.html)
emcon5 11-24-2001 12:38 AM
1 Attachment(s)
I am going to replace my engine sound pad while I have the engine out for a clutch job. I couldn't find any of the 3m "Super" adhesive, all I could find locally was this stuff. Will it work, or should I keep looking?
Thanks,
Tom
FA-18C 11-24-2001 04:59 AM
That stuff works ok for carpeting etc...but I wouldnt go through the trouble of using it with your sound pad...keep looking for the 3M product, or order it from a catalog, JC Whitney and just about any other place has it available
RoninLB 11-24-2001 07:04 AM
I used Dynamat for eng. comp. and trans tunnel.
ebradway 11-24-2001 08:15 AM
While we are on the subject - does the mat insulate the passenger compartment from engine heat as well as sound?
I'm dropping the engine too and my insulation mat has fallen. I was just going to rip the thing out and not replace it. I don't mind hearing the engine better ;)
RoninLB 11-24-2001 10:37 AM
The Dynamat has a thick foil that should keep out heat. Placement in trans. tunnel keeps out that trans. gear whine and road noise muffled.
speeder 11-24-2001 10:52 AM
About the dynamat; is it heavy? And also, did you just put it on tunnel under the carpet? And where the factory sound pad goes?
RoninLB 11-24-2001 11:11 AM
I put it outside when eng/trans was out. Then under carpets. It does have weight. I probally used 50-60 pounds worth all over
campbellcj 11-24-2001 11:59 AM
The heavy engine compartment pad won't stay put with the regular 3M adhesive. BTDT. Lost cause.
Use the heavy-duty stuff, or "carpet glue".
RLJ 11-24-2001 12:01 PM
The "Heavy Duty" 3M works great on engine pad.
Randy Jones
1971 911
bhaubold 11-24-2001 12:01 PM
Is the foil on the dynamat to the outside? Can it be painted. Does it have a self stick backing.
I was thinking of using it in the engine compartment, but want something I can paint.
RoninLB 11-24-2001 12:18 PM
Most of the Dynamat selections have foil on outside. There is one style that doesn't. Chek out their site.
Yargk 11-24-2001 01:39 PM
Sound Pads?.................
We don't need no stinking sound pads
Fishcop 11-24-2001 07:07 PM
Skip the pad, they are a messy hassle. Enjoy the noise!
emcon5 11-24-2001 09:30 PM
Thanks for the replies.
Well, I already have the pad, and the engine is sitting next to the car, so I may as well put it in.
I will keep looking for the good 3M stuff.
Tom
MAS956 11-24-2001 11:07 PM
Tom,
This is the stuff you want to use:
http://www.pelicanparts.com/techarticles/914_sound_pad/914_sound_pad_pic8_big.jpg
It's available for sure at Napa Auto Parts and the counter guys affectionately refer to it as "gorilla snot" which will make complete sense once you start using it.
Good luck.
Mark Sides '82 SC Targa w/new sound pad
dwil 11-25-2001 08:10 PM
I used the dynamat "hoodliner" material on
both my xj6 & 911. It is lightweight, about 5/8"
thick, has the foil on the outside and is self
adhesive on the back. Have had it on the jag
for a year and it shows no sign of coming
loose. The size that it is sold in is large enough
to replace sound pad and cover the lid sheet
metal on the 911.
Wayne 962 11-26-2001 12:40 AM
No, this stuff won't work. WE SELL THE STUFF THAT DOES WORK! As well as 101 Projects, which has this engine pad replacement as one of the projects...
-Wayne
