Coil mounting plate needed?
I have been back dating the heat on my SC and noticed that the coil mounts to a 3 inch by 2 inch steel plate before the whole thing is mounted to the fan housing.
Can I just mount the coil to the fan housing? Does the plate serve a purpose i'm not aware of?
jtp911 |
Do you have AC on your car?
The plate is part fothe factory aC setup. It is there to move coil downwards so it does not hit the condenser on the engine lid. I am guessing your engine looks like this one: ![]() thanks dmcummins
Thanks! That makes sense!
jtp911 |
