-   -   Where to find the engine type number? (http://forums.pelicanparts.com/porsche-911-technical-forum/528003-where-find-engine-type-number.html)
feds 02-23-2010 10:07 PM
Trying to determine which engine I have, but cannot find where the type number is stamped, anybody know?
I have found the number on the side of the fan mount, but I am looking for the 930/___ stamp.
Also, I am trying to determine what the differences are between the ROW, 1984 - 1986, and the 1987 - 1989 3.2's?
woland 02-23-2010 11:24 PM
He SmileWavy
You will find your engine type at the right side of the fan, partially covered by the oil pressure sender (yellow arrow).
http://forums.pelicanparts.com/uploa...1266996185.jpg
You have to clean eventually the alluminium surface and use a small lamp to see better
T77911S 02-24-2010 03:49 AM
yours may be like mine. it does not have one because it was a replacemen case
E Sully 02-24-2010 01:44 PM
Feds,
Grady could give you a much better overview than I ever could, but the number you had in your previous post was it. Will Ferch may have confused you a bit. He started out talking about the cars vin#, but if you read after that he cofirms that the engine# 63Fxxxx is an 85 Row engine. You don't need to look for a 930/_stamp.
feds 02-24-2010 07:52 PM
Thanks.
I do believe that the engine is a ROW engine, however I'm trying to determine if it is the higher compression version of the ROW engines or not.
My understanding (which may not be correct) is that the ROW engines were not all created equal. There is North American and ROW engines, however ROW engines destined for Japan also had the lower compression engines.
The PO told me it had the european high compression engine, however I have since found japanese coins between the seats and other clues that it really came from japan, so I am trying to determine a way to definitively tell if it has the higher compression engine?
I believe the higher compression is due to different pistons, but I'm wondering if anyone knows of other differences?
Also wondering, I have read on here that the ROW transmissions have a cooler, I'm about to change the gear oil and wondering if I have enough as I would imagine the cooler would add to the capacity of the system?
As always, thanks for the input
B61 04-20-2010 11:51 AM
Hello, I recently bought a 911sc from California. This history is not documented. The carnumber is 9118212222. It has a 930/06 engine but i can not find the engine number on the place indicated above. Should i presume it is a replacement case? Is theer a other place to find a engin id?
