Thanks Flieger, Diamondblue, and island911 for the price info . I should have done more "Googling".
Ach du Lieber ! My assumptions about the price of new Fuchs has been confirmed. When I am ready to buy, I will find a good set of used wheels - that have been carefully inspected - from Weidmann or Al Reed. A used set plus the inspection/x-ray certainly must be less expensive than the new ones. |
Sherwood |
You know when I first saw that Magnaflux Quasar machine I could only think of this.:D
<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/RXJKdh1KZ0w&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/RXJKdh1KZ0w&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object> |
...ah, I corrected you - that's why you have a hair up your ass. (squirm squirm) |
Most NDT is something left for a tech to do regardless of what method. A quick check with a 10x glass should be fine. And if you find something questionable, take it to an aircraft mechanic at a nearby airport to have them check it out. That should be the quickest and cheapest route
+1
For a forged wheel, signs of fatigue will show at the surface first. |
An eddy test works on aluminum and is very common in wheel repair and also to test scuba tanks. |
My bad ... shouldn't have used the term "magnaflux" so loosely. (like xerox, Kleenex) the video (a Magnaflux inspection product) isn't using magnetics.
...but, point being, as you say, (magnetic) eddy currents work for Aluminum. (which was my original point) |
OK, we all agree that Aluminum is affected by a magnetic field but has less coupling than does ferrous metal. Eddy currents work to some degree or another on both.
This means that magnetic dye can be used to find those eddy currents along cracks provided the field is strong enough to make it visible. |
(insert icon of dead horse here)
| All times are GMT -8. The time now is 05:44 AM. |
