Where are the idle & WOT switches in 3.2 Carrera?
Trying to determine if the little button in the microswitch is getting stuck resulting in my intermitten fuel pickup problem. Found a couple threads (See thread URL below) that mention unsticking the little button inside the microswitch is one of a few possible solutions. Trying to troubleshoot simple stuff first...
http://forums.pelicanparts.com/porsche-911-technical-forum/444696-bizarre-behavior-need-help-diagnosing-fuel-starvation-issue-1989-911-a-2.html Thanks! |
I think I need to do this test, but I'm not that great at electronics.
I've read the instructions on 911 chips: (Using a multimeter or continuity tester, disconnect the plug and test that the upper two pins (of three) of the switch make contact when your throttle is at least 1/4 of full open. If adjustment is necessary, you can use a blunt screw driver and hammer to tap on one side of the metal mounting tab or the other to rotate the switch to the appropriate angle.)
Sorry for the newbie questions, but I have no idea when it comes to stuff like this. Thank you for your knowledge in this area. |
| All times are GMT -8. The time now is 04:41 AM. |
