-   -   Fuell line size and ID 73.5 vs. 79 CIS (http://forums.pelicanparts.com/porsche-911-technical-forum/528469-fuell-line-size-id-73-5-vs-79-cis.html)
Porsche Head 02-26-2010 04:53 PM
I am tryig to see if the CIS and/or fuel+acumulator I have on my 79 is actually from a 73.5 or 79? I had a PO do the install many years ago and now that I am replacing my pump (Walbro 392) I am checking the lines and seeing if they are up to speed for current and future (Rotrex supercharger) performance.
I measured the pressure line and it is a 8mm line (banjo to rubber to clamped line).
Porsche Head 02-28-2010 08:44 PM
Bump
Why are the fuel filters different 73.5 vs. 78-79 vs. 80 on, is this because of the line sizes? Can someone please measure (calipers) the line in to the filter, it's pretty easy to access, thanks.
I asked PP but they said they don't have the size of the line from the pump to filter so I don't know which to order. The filter I have seems to indicate it's a 73.5 but the engine is a 3.0.
Thanks.SmileWavy
James Brown 02-28-2010 09:04 PM
My 81 hard lines are 12mm OD both supply and return
